Could these be replaced with the car on jack stands or is it required to be raised on a hoist. I had the end links replaced however i still hear minor clunking while going over the bumps.
Thanks.
If you can get under the car, you can change them. You need a deep socket and a flex handle to do the rears.
Yea the fronts can be done with you car jack. I used stands myself (safety First) Make sure you measure your bar because I found it comes in two sizes ,at least for mine.
Thanks for the tip. Mine are 25mm, I had the stealership run my vin before I got them.
