my 96 stalled on me while stopped at a stop sign, got her going then made it home.. Had to go to get some "things" and she wouldnt start only after a few trys? any idea guys? :bash2:
Mr
bad gas? check plug wires? check plugs? throwing any codes?
my car has done that on 3 separate occasions
once it was the crankshaft sensor, once it was the camshaft sensor, both of those are like $40 each & simple to fix ([email protected] shop)
the othe time it was an air leak in like the egr i think its called & didnt pull any codes
does it seem to stall when your going slow or slowing down? thats what mine seemed to do
hope this helps!
[Sent via T-Mobile U360]
the sensors may have codes...
if you replace 1 you should do both of them its so easy to do yourself just need a wrench (just cool off the motor; i burned myself cause im not patient)
