Start troubleshooting using wiring diagrams in FSM (section 8W).
Your terminology may be correct, but I'm not familiar with it. Is "exciter wire" the control wire to the starter solenoid or the large power wire to the starter stud?
I had an intermittent starting issue and found the activator wire 😝 (the small guage wire with the female spade connector) was corroded and snapped off easily. If that's the wire you found low voltage on, maybe try to pierce the wire an inch down the wire and check voltage and crimp a new connector if that's the issue.
