Hmm........
I didn't think steel braided lines were DOT approved for street use yet.
Maybe I'm a little out of date?
I've got them on my Interceptor, but I don't think those are approved either.
Anybody have references to the contrary (ie: approved or not)?
Your brakes do feel a bit firmer because the teflon inner and braided outer prevent fluid pressure from expanding the line as much as a regular "rubber" hose. More of the pressure is applied to the piston instaed of expanding the line. Quicker response, better braking control and firmer feel are the result.
Warlord:
You can get ahold of Russell or any of the other aftermarket suppliers and roll your own if you wish. You just have to wonder if you are capable of making such a critical part related to your safety. I believe the issue with braided lines is the swage where the line meets the fitting not being flexible enough and failing in the whip test brake lines are put through. With a "screw together" line, I would wager the test results are worse than a swaged line.
Cheers
BJ
