1 - 2 of 2 Posts
Hi all,
Would any of you happen to know whether it's possible (or even advisable) to swap out my heater and radiator hoses with steel braided ones? I've had to change the hoses on my valve covers once a year for the past three years and it's getting a little annoying. Would the steel ones do the trick?
Thanks in advance! :)
Yes they will work and they are a nice appearance item. However, keep in mind, it is still a rubber hose on the inside and will age as a normal hose. They are really designed for high pressure applications, but when properly done with the end fittings look really super, although expensive!!!
1 - 2 of 2 Posts
