1 - 1 of 1 Posts
Or should I say Intrepid coupe??? I am in process of getting a 2001 Stratus R/T and darned if it don't look like a 'trep. Has the beefy 3.0that gets more HP than my 04 intrepid 2.7, same trunk and outer style. Our little one no longer needs a car seat and this one is in better condition than the intrepid. Currently suffering from suspension is failing, transmission is failing, A/C clutch is always engaged even when turned off resulting in low gas mileage, power window switch shot driver side, as well as the door panel. more cracks in dash than a geo storm, roach infested from previous owner ( I only had this car since September and ready to bail.) strange gas odor from front but not able to locate the source even with intake plenum removed while cold and cranking to build pressure. I could go on and on, definitely this is a lemon intrepid BUT .... the 2.7 is 9 months old crate replacement from Atlantic Dodge here from previous owner with around 12K miles on it now. I would own another intrepid 2nd gen again but this was the pick of the litter ... basket
1 - 1 of 1 Posts
