Here you go !! :
Headliner
REMOVAL & INSTALLATION
See Figure 1
Fig. 1: Headlining installation
Disconnect the negative battery cable.
Remove the A-pillar trim panels.
Remove overhead console.
Remove screws holding sun visors to roof header and detach the wire connector, if equipped.
Remove the overhead console assembly, if so equipped.
Remove the B-pillar trim panels.
Remove the front and rear assist handles.
Remove the upper quarter trim panels.
Disengage the clip holding the headliner to the roof above the rear window.
Remove the pinch welt holding the headliner to the sun roof opening, if so equipped.
Remove the headliner from the vehicle.
To install:
Install the headliner in the proper position.
Install the pinch welt holding the headliner to the sun roof opening, if so equipped.
Engage the clip holding the headliner to the roof above the rear window.
Install the upper quarter trim panels.
Install the front and rear assist handles.
Install the B-pillar trim panels.
Install overhead console.
Install sun visors to roof header and engage the wire connector, if equipped.
Install the A-pillar trim panels.
Connect the negative battery cable.
Unless you have a moon roof, It is all differant.
