1 - 18 of 18 Posts
Can anyone tell me if some movement is allowed on the strut mount. I recently did different struts with OEM mounts, but not sure if ok this much movement there’s no noises as yet. I’ll will post a small clip as soon I’ll figure out how.
Without checking one of my struts, I would say that's normal. There should be some movement to account for the rotation/angle of the strut when the wheels are turned.
I'll check later this weekend on the special with stock mounts. If someone else does it before then even better!
  • Like
Reactions: JRacecrazy
Is the nut torqued, and if so, is it clamping the mount tightly (at the ID of the mount)?
It was discovered a few years ago by a guy named Stan (RIP) that with some aftermarket struts, the nut bottomed on the strut rod before clamping the mount at the mount ID. That was the case when I installed KYB struts.
The solution was to put a hardened washer on the end of the stut rod before putting the nut on to provide the necessary clamping effect on the mount when the nut is tightened and torqued.
I can't tell by watching the video what is moving relative to what. Is what I described about the nut not clamping tightly to the mount what you are observing?
Yeah when I have the wheel turn side to side is like the shaft do some twist but no noise at all. And I have that special strut tool that’s how I torque down is thighly to the mount
Read Only
I had the exact same thing happen. Take a look at the strut tower studs and nuts. The 4 studs were moving in the holes. It looks like it’s a loose strut nut but it wasn’t. What I ended up doing is getting washers that fit in the hole to take up the slack.
OkI’ll will take a look at that too
never mind
never mind
I have taken the struts apart again and did what you suggested and enginetech72 and the same result I’ll think is not much I can do except find the oem seat& bearing maybe that’s whats what am thinking is wrong I mix a oem mount with aftermarket seat & bearing 🤦🏻‍♂️Opps
Discussion Starter #11
After sometime waiting I finally got 2 oem bearings & seat, but this are a different part # I hope there are not aftermarket drop in the boxes, they don’t have any oem marks or mopar numbers only the box. It will go in combination with the oem L&R mount I already have.
68140264AA is a legit part # for the Seat/Bearing. Should be a real Mopar part.
Discussion Starter #13
I was wondering about that they are coming up as a superseded number I was looking for #4782016 which is long discontinued. It took me some time to find them at because that old number $68 each . Online part store always cancel my order and say no longer available not willing to find them for me. Even the updated part number is says the same.
Google search brings that part # up at several Online dealers no problem. Shows the retail and discounted prices. Normally if it's discontinued there wouldn't be any pricing and would show "Not Available".
Here's your part at Moparpartsgiant:
Discussion Starter #15 (Edited)
Yeah U are right that’s exactly what I did . Through them to and a day later they cancel my order 😆
Where did you get them from? They're in OEM boxes from what I see in your picture.
Discussion Starter #17
Is all good I got them now I’ll be doing the work soon On My old rusty intrepid Lol
1 - 18 of 18 Posts
