Hope you can help.
I love my 1998 Dodge intrepid, 2.7L, 140,000 miles, But the last 45 days I have had this problem, Started when I changed my plugs, new champions, then the car has had this slight miss at idle around 500 - 600 rpms, so I pulled, regapped and reinstalled, still has the miss, Thought it might be the IAC, so I removed and replaced, miss still there, seafoamed through the vaccum Line and changed the PCV and the gummy hose, Miss still there, Turn the A/C car runs like complete crap, (shaking and shuddering). when I drive on the Highway, car is good till I hit 45 - 50 mph then she shudders but past 50 smooths out and runs fine. Checked the vacuum lines all good, cleaned the Throttle body, replaced Air Filter with K&N freshly oiled and installed a Tornado. I got a CEL code 2 days ago for P0302 misfire in #2, swapped coil pack to # 5, reset CEL, now just got the rough idle.
16 June 06 drove home from work roughly 7 miles, CEL on checked codes P0303, slight miss in park and Neutral barely noticeable, idle rough under load.
Can anybody think of anything else? Please Help
Yep, agree with luis, check for a vacuum leak. Check all the hoses, and intake/plenum gaskets are also common places for leaks.
