1 - 2 of 2 Posts
i have mmats 12" juggernaut and i noticed it sounded like crap. i pulled the sub and found a wire coming off of the negative terminal leading into the sub itself was no longer connected to the terminal. if i place the wire into the clip, it sounds ok again. i tried to solder it and the solder simply balls up and rolls off. i am not sure what this loose wire part is called, but i am wondering if it can be fixed? soon as i get my dig cam back, i will take a pic and post, but for now, does anyone have a clue what i am talking about? thanks.
--rudy--
Sounds like you have a broken tinsel lead. Some can be repaired some cannot. Typically this happens either from fatigue or over excursion. Unfortunately, any repair you attempt will shorten it making it more likely to fail again...
1 - 2 of 2 Posts
