Could be a couple things.
Check that your AMP is not overheating, some amps throttle their output while in an overheat mode.
Could also be you subwoofer enclosure if it is a sealed type. If you have a VERY SMALL leak in your box. The ambient air-pressure in the box could be changing during prolonged hi-volume use.
Could also be your electrical system, if your electrical system draws more current than your alternator can produce you will slowly drain your battery and the voltage will drop, this is not uncommon in larger installs with failing alternators. When the system starts failing use a voltmeter to measure the voltage on the + and - power terminals of your amp while the system is running. If the voltage is down near 10V (or lower) than that may be the cause. :bigsmile:
