1 - 11 of 11 Posts
My Intrepid has developed a cloudyness in the lights, and i was wondering if anyone else had any good tips to remove it. I have been using "Flitz" it helps a little, it supposedly has a chemical reaction that takes it away slowly. Any suggestions of what to buy (i dont know if the "kit" works well) but any help would be appreciated. Thanks!
Do a search. You'll find a myriad of suggestions, processes that worked for other members, etc.
Wetsanding is a popular option. PlastX is another possibility. I've heard of other people having good luck with Plexus.
I use plexus as a preventative, but it won't clear lights already damaged. Most of the successes here have involved sanding and polishing with a product like plast-x. There are also some sealant products, that re-coat lenses that some have has luck with. As W3ap0n-X said, there are lots of threads on this topic.
theres a kit at walmart in a silver bag. i found it in the automotive section by the headlight bulbs. others found it in different areas of wallyworld. its a little under 20 bucks, and has everything you need.
1500 and 2000 sand paper, buffer, sealer
i did it, and didnt take my time, only sanded for about 2 minutes per light, and it took about 15 mins total to do both headlights and foglights. i wasnt trying to make it perfect, just to see if it even made a difference.
it looked awesome.
ive been debating getting another kit and redoing it. i put a thin coat of the sealer, and want to resand everything down real good and put 4 coats of sealer this time.
i would reccomend the kit. it has everything you need and its all in one package.
I had the same problem with my intrepid - had almost no light and had to use hi-beams all the time. I used 3M's Scratch Remover just as I would on the body and it worked like a dream. It is safe for clearcoat so it doesn't scratch the lenses. May require a few rubbings but it is worth it (and much cheaper than those cleaning "kits") Do your fogs too, if you have them. You will be amazed!!
I dont have this problem, but when I went to the Salvage yard, all the intrepid Head lights had this to a degree. I am curious then is the fogging just on the outside of the plastic so that the sanding gets you down to where it is now clear? I ask this because new OEM light cost approx. 200 each. The head lights in the yard were $23 each. If they can be reworked then that seems like a good alternative. Assuming of course that the fogging is just on the outside and not all the way through. I also heard that is caused by UV light damage? On all model years or just some??
I use Rain-X on the headlight lenses even though I believe the instructions say it's not for plastic. I've done this for years, since lenses went from glass to plastic, and have not had foggy lenses yet.
Knocking on wood.
You can buy a kit or not, but if your lights are damaged pretty well, then you will need to wet sand them.
--Veeborg
--Veeborg
okay did i miss something? whats up with all the cross naming?
--insertmod"sn"here
sorry for the hi-jack. i use this stuff from pep-boys that cleans convertable tops. i forget the exact brand but the guys use it on all the cars they inspect and turned me on to it when i was getting my headlight bulb changed a while ago.
1 - 11 of 11 Posts
