1 - 1 of 1 Posts
I posted a couple weeks ago about a surging problem. or more acurately, the rpm will drop to a couple hundred, then if the car doesn't die, it will zoom back to 1500 then smooth out. This cycle happens every 10 to 15 seconds.
I've done everything, good fuel pressure, checked for leaks and found a small one (egr gasket). One of my friends has suggested the TPS and CPS. So, with a little bit more than the average tools around, how do I check those?
OCB II gave a 1391 code, which has something to do with the brakes, so that's another issue.
Thanks
Tom
1 - 1 of 1 Posts
