21 - 26 of 26 Posts
could i jack up the back and put the front on ramps?
Jack up first, and then replace with jack stands for maximum stability. Stability is important - especially when any part of you is going to be betwen the car and the ground. 馃憤
  • Like
Reactions: hazel
Discussion Starter · #23 ·
yea i have the stands n stuff i was mostly wondering if that would simulate ride height well enough, worst case i just put it on blocks
Any incline angle will decrease the amount of strut spring compression.
True, but the ramps would have to be 16 inches tall to make 1% difference... 8 inch high ramps would make 0.25% difference (about 9 pounds total weight).
Notice that the service manual doesn't call for weight to be added to the car to simulate the passenger weight either.
Tightened at full drop = disaster; tighten within 1% of full load - no problem.
  • Like
Reactions: peva
"Tightened at full drop = disaster; tighten within 1% of full load - no problem."
Right on! I concede.
Your Chief Soh Cah Toa math is correct. 113" wheelbase, 16" => 8掳, cos 8掳 = 0.9903; 8" => 4掳, cos 4掳 = 0.9976. 馃榿
ok so update: the control arm has been removed from the chassis, now i just need to get the arm off of the strut tension arm. its really stuck on there, any ideas? also i still could use those torque specs if anyone has them, would really appreciate it!
I had the exact problem i ended up just cutting it off with an angle grinder i hit a fence on the right side and had to replace basically everything you just mentioned but i dont know the torque specs as i use the feel method
21 - 26 of 26 Posts
