I'm going to order a set of RT iRotors using our group discount, a set of HPS Hawk pads and Eibach pro kit springs. My question, is it okay to have the rotors, brakes and the springs installed on 16 inch rims then later on swapped to 17 inch rims? I want to wear the 16s in my sig during the winter then wear the new 17s after the snow season.
From what I have seen lately, iRotors no longer offers the PHP style rotors for the front. The R/T uses the PHP style rotors.
As long as the overall diameter (wheel + tire) remains the same, you won't have any noticeable speedo issues.
I run the stock 17" rims in the winter and run 18" aftermarket rims in the summer. I've had no issues. You'll only run into issues if you go below 16" rims (as in the rims won't fit around the calipers).
