Just curious, does anyone know the ratio of dino/synthetic in a blend such as Mobil1? I would assume by the price it's about 75/25.
So, either go with full synth or full dino. What's the point.
I think I heard from other members here that if you are going to use a blend, to make it yourself. Just use the same brand dino and synth and you should be fine. And then you control the ratio.
i would think 4reg to 1 full synthetic would be just fine to make up the oil in the car.
i think just regular maintance is good enough, but i just use Valvoline 10-40 All climate. in both trepids and both run like champs and i'm dang careful about changing the oil around 300-500 miles early. and i've done this on 5 different cars and not yet had to deal with internal engine damage yet :)
