i have a 95' 3.3L and when i start the car sometimes all the tachs don't work and when i try to drive it won't switch gears and then eventually the tachs will pop on and it will start to switch gears . i was just wondering if anyone knows what this could be if you got a idea of why please help me out. thanks :fun_71:
The tach operate's off the Crank Sensor, but it sounds like your having a problem with your Output Sensor on your tranny though.
could be a crank/cam sensor, if the computer can't see the rpms it won't shift.
[not a chrysler tech...just a guess]
the speedomator, gas gauge, and rpm tach isn't working when you turn it on so i thought it might be the whole gauge consoule wasn't working but the blinkers show up so i knew it had to be something else . i didn't think it was the output sensor on the tranny because of the gas gauge and the speedomator not working either
it might be a cluster problem...the tach/gas/speedo are on a different setup than the blinkers/high beam bulb/etc
