1 - 20 of 39 Posts
Obviously ANY car can break down but I meant it's never broken down WHILE you are driving, right? Wouldn't you say it's a very reliable car that you can count on to get you from point A to point B 99.9% of the time? I've only had a flat front left tire while I drove.
I had a 99 Mazda Protege for 6 years and a 2000 Malibu for 3 years and neither of them ever broke down and the Intrepid had a higher consumer satisfaction rating than the Malibu and maybe the Protege too.
So has an Intrepid ever broken down WHILE you were driving and how would you assess its reliability?
Every car I've had broke down at one time or another, then again I average about 60,000 miles a year. The worst I've had was my 93 Concorde. That damn thing was cursed. Constantly broke down. I had it for 2 years in that time it... Overheated at least 5 times, lost spark, fuel pump went out, trans died, steering went, pressure tank blew up, radiator blew up, trans died again, fixed the damn thing and sold it. Then again my 2000 intrepid no problems whatsoever, and its a 2.7.
My Concorde has never broke down while driving it ( I know as soon as I post this, it will happen ) in the seven years that I've had it.
It does have a hard start when it's super cold out and it sat all week. 15 min with the block heater plugged in, solves that issue. It runs like a champ after that though.
I think it's time for new plugs.
I've had it start misfiring on my way to work. But that was my fault in the quarter carwash. When my mom owned it, it broke down on her when the battery died. Not really an Intrepid only problem but it did happen.
only had it break down once, and that is when the camshaft position sensor went out
Intrepid 100,000 kms of use Starter,and battery (not at same time) and not with out warning!
Concord 100,000 kms of use idler siezed took waterpump did timing belt,on road at time but limped off towed to shop.
LHS 30,000 kms of use no letdowns yet
There are of course the front end repairs and brakes, brakes, brakes!
Only had mine need to be towed once. That was the tranny when I fried the second gear clutch pack banging second at 6300 rpm on track during an auto cross event (car had 208,000 at the time). I have to think it would NOT have expired in normal use. Even at that it would have made it home in second without issue, I was over 120 miles from home and a bit paranoid. Starters and alternators give signs as they get close. I even DROVE it to the shop with a flywheel center broken free from the flywheel! Has been a simply great car! I have owned it for 8 1/2 years and personally put on 224,000 miles (purchased with 42,000) on it and have no intention to retire it.
Dain bramaged
One flat tire due to a screw in it, tierod came apart after ignoring it for 4 months and then a fuel pump failure. I've owned it since '00 and its gotten me home every other time.
*if you knew how hard i was on my car, you'd understand. Doing the work I do, the car would idle for 6-8 hours a night, 5 nights a week for like 3 years*
I must say that my Intrepid(when I had it) NEVER broke down on me. It had 140k miles(All original parts) and not one thing happened to me while I was driving it,
I replaced: Lower ball joints
Rear main seal
spark plugs
PCV valve
tie rods
Drive belt/A/C belt
As you can see; all I basically did was basic maintainence. My neighbors purchased the car and had it since June with no problems *knock on wood*
My only beef with these cars is the waterpump inside the crank case(2.7) and the fuel filters in the tank!!!!!
Other than that, your Intrepid will treat you right if you treat it right ;)
Rear main seal
spark plugs
PCV valve
tie rods
Drive belt/A/C belt
Fuel filters in the fuel tank are the way of the future. Since they are plastic, nothing corrodes or flakes off, unlike steel. And they are a helluva lot lighter, and never rust out. I honestly think you could count on one hand the number of people in LH land that have had to replace their fuel pump in a 2nd Gen.
.For the past 3 years, at the end of each summer I've had to shell out $700-800 dollars for a repair. First the rear struts, then the tranny, then the front struts. Along with a few other less expensive repairs (tie rods, wheel bearings, etc.). But it is a northern car and is at that age when things start breaking. I would consider it a reliable car, and I do love it.
Reliable MOSTLY has to do with the owner's maintenance program. Many failures are due to neglect or lack of preventative. Some that do not fit under this catagory are sensors. Cam, crank, speed etc. Some will last a lifetime. Some fail without warning. Not even sure if you can trust a new one over a 5 year old one.
I had my first break down yesterday. Brake pedal to the floor. Rear line sprung a leak, lost fluid. I would have advised anyone in that situation to tow the car. Me. I'm a little stubborn and refilled the master and drove it to a garage.
Is this the owner's fault. I say yes. My last car was a Chevrolet Celebrity. Rotted it's fuel and brake lines out too. So the LHS was oil sprayed a few times to try to prevent that. Guess what. The area that was missed, rusted out. I also blame the manufacturer for not using a higher quality line.
The LHS has also been towed before. Sure it looked damn unreliable as the flashing light tow truck with it's reversing siren dropped it off. Problem. Brake was making noise. Diagnosis. Rear disc has a mini drum set up for a parking brake. A small chuck broke off and was rubbing. Wife refused to drive it. Minor.
Reliability also has alot to do with your frame of mind. A tire blow out on the highway and finding a flat on a Saturday afternoon is technically the same but one makes a mark in your memory and one is just a minor set back.
I never considered a broken brake line a cause for a tow. I drove my old Gutlass for a week with the rear brakes non-existant, for a week, due to no money and need to get to work.
My Concorde blew a rear line, but since I have a brand new car for the family nowadays, I just didn't use it until I had a little extra time to put in new lines.
The only time my car was towed was when I didn't stop at a stop sign after leaving a bar.:all_cohol
Maintenance Free so far.
80,xxx km for an 02 3.5L HO, no issues at all. Never towed, never left me stranded or without a car. Very versatile for its size, just cant fit large items like audio stuff due to trunk opening, but it fits in the back seat. Ive even carried a motorcycle engine in the rear bench area (removed bench) and placed the 200lbs motor on the body metal.
So far mechanically i just spent money on synthetic oil changes and fuel. Had a slight issue with cheap rotors getting warped but i think its solved now. Nothing mechanical has broken down that i would consider major. My previous 96 Bonneville SSEI went through an alternator, accessory belts, struts, list was endless + body rust :(
One little issue it had was when i flooded it once by accident and it wouldnt start for like 5min. It doesnt deal very well with cold starts, it needs time to warm up in the winter.
So far i would say its by far very reliable despite what others say. Keep in mind im 22 and ive had the car since new, so throughout its lifetime its seen redlines, higher than rated posted speed limits, towing my toys, etc..
Im glad its reliable so i can put repair money into mods LOL.
Owned my 2001 Intrepid SE for 5 years, never broke down. Was one of the most relaible cars I've ever owned. Actually was the longest I've ever owned a car before trading it in on something else...
Discussion Starter #17
It's good to hear all you guys have had the same reliable experience I have except for the guy who actually drove his Trep on a RACE TRACK!!?! Is the Intrepid really meant for that??
The main thing I don't like is the AWFUL fuel efficiency at only 15.9 mpg according to my OTIS computer!! :banghead:
:9lame:
Don't worry about it!! I took my 2.7 down to the local drag strip in August with just over 150,000 miles on it. I think I did like 14 runs!!
The main thing I don't like is the AWFUL fuel efficiency at only 15.9 mpg according to my OTIS computer!! :banghead::9lame:
Hmm, you might just need a general tune-up. Still, if you drive 100% in the city, 15.9 mpg isn't that far off. Especially now that it has gotten colder out.
Dain bramaged
:9lame:
I've taken my trep to the dragstrip several times, its not the fastest thing in the world, but its consistant.
I average 30mpg highway according to my otis.. :drool:
:9lame:
You are always going to get stupid people that bash the intrepid because OMG they just realized its not a sports car. I guess they missed the 4 doors, huge trunk, FWD, and pricetag. I think compared to other vehicles in its class its pretty quick, i mean it still has a lot of punch to it even after some time and can keep up with new cars that should be superior to the intrepid design.
intrepid.luvah is one of those idiots that talks about the intrepid like its a racecar. Now lets be honest, its great for the money and its very reliable for an american product. I also like that it doesnt have that old car feel to it even tho it too ages. I got into my friends 05 focus the other day and it has 20,000 km, it felt like it was gonna fall apart. Everything was loose and it looked really old.
As for the fuel efficiency, im getting pretty bad numbers myself, but it gets even worse towing.
I get 21mpg city with my 3.5HO running on 89 to premium, now that gas prices have fallen i just run premium LOL... at 52 cents/L (after discount), its really worth it hahhaha.
But when its towing my jet ski, WOW 13.5 mpg is the average. Its pretty good compared to other cars out there with the same engine. Minivans for some odd reason are very good on gas, even towing. My dads work van is a 3.4L v6 and will get a consistent 28 mpg in the city/highway and 26mpg highway towing and fully packed with luggage, maybe its the way the weight is distributed/transmission ratios.
Funny you mention mpg, have you seen mpg for boats/ jet skis?
I dont know about many boats but my jet is a 1494cc engine 3 cylinder supercharged rotax, at WOT (8100rpm) it eats 70L/Hr, a fuel efficiency of 2 MPG. Im just glad fuel costs have fallen, pumping 91 into it at over 1.45$/L was a real *****. So ive learned to love the efficiency of cars.
4 MPH 1800 RPM 9 MPG (idle)
20 MPH 4000 RPM 7.5 - 8 MPG
30 MPH 4700 RPM 6.5 - 7 MPG
45 MPH 5500 RPM 5.5 MPG
55 MPH 6500 RPM 4.5 MPG
65 MPH 7400 RPM 3.5 MPG
72 MPH 8100 RPM 2 MPG WOT
1 - 20 of 39 Posts
