1 - 16 of 16 Posts
Mods
Interior
EVIC
MTC to ATC (without body harness swap)
Auto headlight switch (illuminated)
300M 200Kph/120Mph cluster
300M Seats
300M Chrome switches, Door handles & Shifter
Dyed Tan interior to black.
Audio
Kenwood deck, 10" Sub x2, kenwood doors and rear deck speakers, Legacy Series 2 four channel 1200 watt & Boss 1100 Watt Class D Mono block amp, Boss 18 Farad Digital Hybrid Capacitor with Blue Illumination
Sirius XM, Antenna mounted on rear deck by rear window.
Exterior
300M Memory Mirrors with defroster
Flowmaster 80 muffler single in dual out 2.5".
LED's across trunk lid set as 3rd brake light
Debadged hood and replaced with Decepticon logo
35% Tinting on windows
Syper Dual Halo Projection headlights,(H1 low beam & 9005 high beam)
Mechanical
Autostick
Traction Control
K&N Air filter custom 3" Aluminum piping
Bored out Throttle body from 62mm to 68mm
Remote Start
The gauges I have there are the "Old Tyme 2 white" series.. (you can see a close up of each guage)
The ones I wanted to put in were " VDO cockpit royal". (the last attachment)
They would have been an exact match with the 300 cluster but they were too pricy.
Discussion Starter #14
Besides my tail light mod, this is the best I've seen. Great Job!
Thanks.. Really like yours, was trying to find out how you did yours.
Exhaust sounds good! What have you got on her?
Flowmaster 80 single 3inch in and dual 2.5 out. Found the Muffler on Kijiji came off a Camaro. Picked it up for $40 then took it to a custom muffler place & they put it on for $100. Took a bit of custom work to get it on.. they removed both mufflers, made a step-up from 2 1/4 inch stock pipe to 3 inch to fit the muffler. then they made the Tail pipes.
Only took about an hour to do.
1 - 16 of 16 Posts
