Group,
I got the M dynoed at Carlisle...to see what is up with my car....
Here are the results:
Weather Conditions:
Air Temp: 83*F
Absolute Barometric Pressure: 29.90 in Hg.
Vapor Pressure: ~ .2 in Hg.
Max HP (SAE Corrected): 173.4
Max Torque (SAE Corrected): 193.8
Correction Factor: .99
At 30% Drivetrain Loss, the estimated numbers:
HP: 248 HP
Torque: 277 Lb/Ft
At 33% Drivetrain Loss, the estimated numbers:
HP: 259 HP
Torque: 289 Lb/Ft
As you can see, the torque curve has been shifted down towards the basement by around 500 - 800 RPM.
The 3/8" Spacer is doing what it should....
What do you guys think??
Weather Conditions:
Air Temp: 83*F
HP: 248 HP
Torque: 277 Lb/Ft
HP: 259 HP
Torque: 289 Lb/Ft
