1 - 20 of 63 Posts
soooo, in my mind to repair the damage done in my accident.. i have come up with the plan to get everything new ... NOW ... since im going to be getting NEW headlight assem.'s im going to go with and HID kit (any opinions on what to go for with brand??) ... new headlight casings or housings ... whatever u want to call it ... possibly new hood?? since i did an A/C delete i might go and do a C.A.I. instead of short ram since i now hace plenty of room lol ... hmmm so many new ideas?????? ... and since this happened ... the paint job has been put on hold... got one side of car sanded and thats it lol :smileyvault-newhere
bump....i plan on going HID'S as well i just don't know if the output of the bulbs are going to burn the housing....i would like to know about this as well
Im running a 35w kit with 5000k bi-xenon bulbs from DDM Tuning in mine but i don't suggest going with there kits because they only ship from china and there slower than a snail shitting a brick.
Also there replay harness sucks ass as much as there customer service.
Look through my thread and see all the crap i went through to get them to work properly.
http://www.dodgeintrepid.net/showthread.php?t=219329
looks good though even for one bad ground that u fixed...yah i hate the whole shipping from china deal...that happened to me with a led lit laptop cooler i ordered for my ps3 but then again i can't complain..it only cost me $3
The term plug and play just means that you don't have splice into the vehicles wiring harness because there is a male 9007 plug connects to the drivers side 9007 headlight plug that only turns on the headlights.
Mine is plug and play.
ok so pretty simple then??? or is there problems ... and i did some reading on it and im taking a guess here that you only have low beam only and high beam is deleted??
ok also a question about radiator size ... whats the difference between a 1 row and a 2 row radiator ... would that consist of taking place of the A/C cooling tank??? like meaning 2"???? lol im new at this stuff so i have absolutely no idea
this is supposedly the "2 row"
http://www.ebay.com/itm/Brand-New-2...trepid|Make:Dodge&hash=item5d32b52b4a&vxp=mtr
Item specifics
Outlet Header: 2-3/8 x 15-5/8
Part Number: 53122
Transmission Oil Cooler: 10 in.
Inlet Header: 2-3/8 x 15-5/8
Mount Type: Bracket
Inlet Connection: 1-1/4 right
Outlet Connection: 1-1/4 left
Weight: 19
Number Of Rows: 2
Engine Oil Cooler: none
Dimensions: 25 x 14-7/8 x 1-1/4
this is the "1 row"
http://www.ebay.com/itm/Brand-New-1...trepid|Make:Dodge&hash=item5d32b52b09&vxp=mtr
Item specifics
Outlet Header: 15-5/8 x 2-3/8
Part Number: 16189
Inlet Header: 15-5/8 x 2-3/8
Mount Type: Flange
Weight: 11
Number Of Rows: 1
Dimensions: 14-7/8 x 25 x 1
The install is very simple so long as the kit you purchase doesn't give you problems like mine having a crappy relay harness.
The kit that i bought is called a bi-xenon kit which means that the bulb is xenon gas high and low that magnetically changed when you turn on the high beams where some kits are xenon gas low with a halogen high beam.attached to the side of the xenon bulb.
Discussion Starter #11
so in ur opinion what would u say is better...the bi- xenon or the reg xenon???
First don't buy from that seller because number 1 at $68.00 those radiators have got to be garbage and second the reviews for that seller suck.
As far as single vs double row goes the double is twice the cooling area but honestly is not needed in a daily driver.
Discussion Starter #13
yea i saw all that ... it was just an example ... and i was just looking for something to fill the A/C gap
I'm going to say that the HID bulb in this case is like any other with a gas filled capsule that illuminates when hit with high voltage(like all true HID or true Xenon bulb)s.
A 1st gen halogen bulb has two filaments that are at different distances from the bulb base. High or Low beam is selected on those bulbs by lighting up one or the other filament. They use the same headlight housing with one bulb. The beam is focused differently depending on which filament is lit.
With these HID bulbs there's only one "filament"...the gas capsule which is a set distance from the bulb base. To mimic the typical dual filament halogen bulb....the HID bulb base has a solenoid in it. When activated it moves the gas capsule to a different distance from the bulb base. Either in or out. That changes the position of the gas capsule in relation to the bulb base and effectively changes High/Low beam.
Probably too technical of a description..but that's how it works.
Honestly you can as many people have go with a single stage low beam only xenon kit because light output is so much better you wont ever have to use the high beams.
Personally i like everything to function properly which is why i chose the Bi-xenon.
Discussion Starter #17
and i dont kno about inspection laws but i think both hi's and low's have to work in the state of pa
When you find a kit that gets good reviews that's in your price range stay with a 35 watt kit and get the 5000k bulbs.
Anything higher than 5000k you actually lose light output.
1 - 20 of 63 Posts
