1 - 10 of 10 Posts
So my 01 Intrepid with the 3.5 engine has been running hot and I diagnosed as the thermostat is not working the lower radiator hose is much cooler than the top. So I called the Dodge dealer and they do have a thermostat but not the seal they said it's discontinued now what?
I was going to go with the OEM thermostat from what I have read on here, but need to know what kind of seal seal I can get and from where thanks.
Or should I just go with aftermarket?
BTW where are the parts microfiche located?
thanks,
Gary
See if you can access my Onedrive link above for the 2001 Parts Catalog?
  • Like
Reactions: G-man
  • Like
Reactions: G-man
It wants me to sign up for one drive.
It won't enlarge?
Thanks
Check out post no. 11 here (also courtesy of Ronbo):
  • Like
Reactions: G-man
It won't enlarge?
Thanks
Forgot about attachments. The parts catalogs are small enough to post as a single file attachment.
Try this......
  • Like
Reactions: G-man
Try this......
Discussion Starter · #8 ·
Try this......
That works great 👍!
Thanks very much Ronbo!
I got a Gates thermostat that I'm gonna replace the original with. People trust Gates water pumps and timing belts so I don't see the issue with their thermostat. Also gaskets are just that. I don't think that's something that HAS to be OEM.
1 - 10 of 10 Posts
