1 - 20 of 32 Posts
Well, it happend tonight, I was going to buy the parts to do it this week ironically. It held on enough to get me home, either the water pump seized, which is what i think happened cause it has been leaking or the tensioner did, or neither. The belt just started to squeal, then flop flop flop. I'm gonna go part shopping tomorrow morning, and get a new pump, belt and tensioner, and spend my day doing that. Hopefully everything goes smooth. Any input or things to look out for is apprectiated.
So the project begins...this is going to be a looooong day.
lol, i just got done taking the fans out...yeah, forgot the catch pan for teh coolant, hope i dont kill any animals out around my driveway...
Well, I got held up a little bit due to a rusted/stripped bolt on the timing cover right below the thermostat, but I was able to get it off with some WD-40 and hammering a smaller socket onto it. Everythings apart at the moment, tensioner pulley was the one that seized, im replacing it, the water pump and belt. Belt isnt shredded, just frayed quite a bit and theres lots of rubber build up in the bottom of the timing case. I'll get some pics of the install up tonight. :D
yeah, piston was fine.
well everything went great, everything is back up and running without problems, I'll try to post some pics soon.
congrats, glad to hear that your car is running again. I was wondering how difficult was it to replace all teh parts today? Thanks again
Discussion Starter #13 (Edited)
It wasnt all the difficult, just time consuming, Axle and Justin helped me quite a bit cause I had never done it before. Advice would be just to make sure the timing is correct, I set it, then after I put tensioner back on, it was off, so I had to take it off and reset it. Other than that, the fans are a pain in the ass to take off and I had some rusted/stripped bolts. All in all, not that bad of a job considering shops charge 700+ for it.
Here's some pics:
Early stages of removal
Old tensioner
New tensioner
Taking old belt off
Before I took water pump out
New water pump, o-ring, and timing belt
Old pump, belt, tensioner
After I removed old water pump (coolant everywhere lol)
95Intrepisize said:
When mine went it blew the heads. Check those.
[hijack]where do you live in michigan? my mom just moved from detroit to cadillac and im trying to figure out what there is to do up there[/hijack]
Discussion Starter #16
01redMS said:
your car is probably pretty slow huh?
not anymore :sly:
Just an idea for people that do this in the future, when I do this I go ahead and leave the fans bolted to the radiator and pull the fans and radiator as one unit. really not that bad, pluss gives you a little more room to work. Just an idea.
-Taaf-
Discussion Starter #19
01redMS said:
have you run it at the track? im so curious as to what it would run
no, but hopefully soon
I am heading to the local 1/8 mile next sat the 20 I have almost teh same setup on my car so I will let you know what mine soes I only have a 75 hp nitrous setup right now but I think that I will do okay against most of the imports. Thanks for the pictures and the tips
1 - 20 of 32 Posts
