Hello, I am replacing the timing cover after changing the water pump. I bagged all of the cover bolts together but on re assembly I cannot remember which timing cover bolt hole had the torx head bolt instead of the 10 mm bolt.
Thanks in advance
Discussion Starter #2
I think I found the position for the torx bolt.. I found a YouTube video where a mechanic was removing a water pump. The torx bolt looks like it goes just above the bolt hole for the belt tensioner on the AC compressor side. Correct me if I am wrong.
Thanks
You have a 3.2 or 3.5 right? It goes on the passenger side of the short runner module on the intake manifold.
