Not sure what the stock size is for an R/T but my 01 SE has 225's, so you're a bit wider that the base.Avenger said:Lol 255
Rims weigh 31lbs each too.......stock was 23lbs I think.
That's another good point. Depending on the size of the new rims and tires and how close they are to stock diameter (its easier to measure than circumference) then it can throw your speedo off a little bit. If in fact that were the case where your speedo (and odo) clocks one mile when you actually traveled 105% of that (for example), then your odo will be clocking less than the actual miles you've traveled, and thus less miles when compared to the same amount of gas used. Post what the stock size wheels and tires were and what the new tires and wheels are. Post the complete size ie. "Pxxx/xx Rxx" and we'll see how close they are and if it could be affecting things.Torontofirecaptain said:Another thing to consider is that the circumferance of your previous tires and your new ones is probably not the same, so your "mileage" readout will not reflect the true distance when you calculate your MPG (or the EVIC's calculating it)
My 245s are about 5% smaller, so when the car thinks it is 100KPH, it is really 95 - out by 5%, as is the distance, so you need to adjust accordingly.
My recent trip to US got me an average of 24.9 miles per US gallon (just around 30 to Imperial gallon) over 1200 miles; combination of 75-80 mph & mountains of Pennsylvania.
I put 245/45/18 and I didn't notice any drop in fuel economy, I still got around 22 MPG .Avenger said:Anyone else who installed 20's notice a drop in fuel economy?
I used to sit around 20MPG, but now I'm at 18.0 MPG.......sounds pretty bad huh? No, I don't have a lead foot.......just my car loves the fuel for some reason.
Rob
Me to Great White.Even when i put on the 17" 300m rims,i still got great gas mileage.I don't think imma go any bigger than 18's..Great White said:Holy crap! 18.5 mpg.
I don't think mine even dropped that low in winter!
I have the stock 16's and get between 28-32 ish. Worst average I saw in winter was around 22-24ish.
cheers
BJ
O yea, this is common.. I had the same problem with other cars also, smooth ride on flat surface, zigzag driving on uneven road.Out_Cold1999 said:Has anyone else with the wider tires noticed that over uneven roads your car kinda goes wherever it wants? I find myself fighting my car on rough roads way more than when I had just the stockers on...
