I've removed the upper dash cover to install a sunload sensor. I don't see a 4 connector plug, but do see a 2 wire plug (both orange wires). is this for center speaker or sunload sensor?
What year car?
Center Dash Speaker for a 2002 car is Pink with a Black Stripe and Pink with a Red Stripe.
Sun Sensor/VTSS LED has 4 wires.
Looks like you'll need to add some wiring.
OK.. i'm a dumbass.. I was working at dusk and didn't realize the 4pin connector was taped down. Found it and Sunload is all dropped in.. I did crack both the center speaker and driver's side grillwork.. :(
You're one of the lucky ones. Most 2002-2004 cars didn't have that wiring if it wasn't optioned with it.
Did you do this for the Auto Headlight switch?
