1 - 14 of 14 Posts
How do you install tracytion control on a non trac. con. equipped vehicle? i know that there are wires where the switch is, but is it anything more involved? Thanks, David
Hmm i do not know for sure but i think that it is also a different ABS pump all together, along with different ABS sensors? I am pretty sure about the pump but am not sure about the sensors. Also the a computer difference i think as well
Nope, I bought a switch for mine hoping it would make the trac lights work, but it doesn't even do that. Like gr8crash said... you do have to change out the ABS pump to an ABS+Trac pump. I don't think the wheel sensors are different though I may be wrong. I think there may be a setting on the PCM also, that would have to be changed by the dealer, don't quote me there either though.
To get traction Control into a car that doesnt have it you need:
ABS pump With Traction
ABS computer Mark Teves with TC
Master Cylinder with Traction (there are different valves in it)
Sensors are the same
dealer flash or PCM from a car that came with it
Last, a trac switch
Not worth it... the traction control in the LH isnt advanced like the trac in say a Benz where it retards timing, stops throttle, changes tranny gear and if all else fails, then applies the brakes... The trac in the LH is good, but not worth the aggrivation...
Then after everything is installed the system would need to be bled by someone who has a DRB to pump the motor... PITA!
1 - 14 of 14 Posts
