might be picking up a 94 Intrepid soon, owner tells me it needs a tranny mount... how hard is this to replace?
OMG - where could I go with "Tranny mounts - how hard"
Bwahaaahaaa!!!
If you can get the car up in the air, and you are comfy under it. They are pretty easy. Unbolt the four bolts holding the mount in, jack up the back of the tranny a lil, unbolt the bolt through the mount and the tranny, remove mount, install new one in revers order. The bolts are usualy nice and greasy so they are not hard to break loose. Just don't slip off of them.
-Taaf-
Bwahaaahaaa!!!
did I miss something?
I had just watched an episode of Celebreality. A current guest in the house is a "tranny"...mount a tranny - how hard is it
