1 - 2 of 2 Posts
Hey Guys. I have a problem with my 2002 Intrepid tranny. The problem is that my engine runs fine but yesterday the transmission slipped and now won’t go anywhere. When I first start the car I can shift into any gear and it will move fine for about 10 seconds and then the tranny simply slips and spins away and the car doesn’t move. You can shut the car off and start it again and it does the same thing all over again. If you rev the engine the tranny will sometimes make a strange whining sound and then kick in gear for a few seconds and then just slip and let go again. I did run a standard engine code check with the handheld computer from autozone and the three codes were P0700, P0736 and P0846. I did add some fluid to the tranny to make sure it had enough and it didn’t take much. Same issue. If anyone has any thoughts or suggestions I am all ears – I don’t have the cash to pay a dealer to fix this!!
so have you taken the time to find out the meaning of P0736 and P0846?
1 - 2 of 2 Posts
