can someone tell me what (dtc) means in the code table .my 97 just set off this code and is now in limp mode......? Thanks in advance.
DTC is Diagnostic Trouble Codes.
What trans. problems are you having?
A bad speed sensor might be a possibility.
Well it was running fine ,then the other night i went to drive it and it wouldn't shift into 3-4th gear. It just stays in 2nd....
Most likely your input or output speed sensors.. I would go ahead and replace both to be on the safe side, then disconnect the battery for 15 mins.. That SHOULD fix your problems.
thanks i'll give it a try ! ... man i've replaced about every sensor on this car,recently . But!!! i still love driving this car.Even if it has 215k miles on it!!!
yo its ur out put sensor same thing happen to me does it jerk when u shift from p to r to d ? if so its ur out put
Mopar or No Car
I think it could be either sensor. The way I've always heard it is if the output sensor is bad the speedo won't work. But I'd replace both anyway - if you've got 215k on it then you're on borrowed time. The sensors don't cost that much and, personally, I'd get 'em from the dealer ...
