1996 with 3.5L and around 165,000miles.
I was replacing the drivers side cv half axle today (torn boot and some road noise) and checked the passenger side (transaxle/differential).
There was some wobble way up at the output stub shaft.
Not the in/out but the up/down/left/right. It wasn't major movement (maybe 1/16") but enough to get me to pull the half axle off and look things over.
The seal is ok and everything looks ok.
Question is: Should there be some wobble as decribed above on this output stub shaft?
KP
KP
