Added Drain Plug to my trans pan this time around to make fluid and filter changes less sloppy in the future.
This is what the local Advanced had in stock. $3.59
Install is straight forward. Select location, drill 1/2" hole, deburr, install.
I added a bit of sealer to the nylon washers just in case. Considered using copper washers (if it leaks in the future I will change)
The drain plug itself has an oring that seals in a chamfer, again may replace with copper washer if it leaks.
This was done in 2009 and still dry as the day Installed it.
One other member put his cordless drill in a plastic bag and drilled in to drain first time. Just don't go to deep!
