Ok going off of this post in another thread:
D76G12 said:
Tranny - Make sure you stick with a good maintenance schedule on these and make sure you use ATF+4 fluid - no substitutes or "ATF+4 complaint" labels. They're not the same and have caused problems for several people. IMO - the minimum interval should be 48k miles as called for under schedule "B" in the owner's manual.
I already have a brand new filter and gasket in my trunk right now... Last time my transmission fluid and filter was changed out was a tad bit over 40,000 miles ago (It was done by the local 5 star dealer). How many quarts of tranny oil should I add? Is there anything else that I need to know before I do this?
~TIA~
Tony
P.S.
And yes I know ATF+4 ;)
