Ok - FSM's description of the procedure to remove the tranny pan SOUNDS good, but boy was I in for a rude awakening upon execution!
12 of the bolts came out NO problemo. The 13th, nearest the drivers' side exhaust pipe, was a total bear - gotta wonder if my exhaust is a bit outta whack - I had a helluva time getting a socket onto that one bolt - hardly any clearance. Anyhoo - success.
It appears that the trans filter has been replaced at some point (good news), but they used RTV to seal the pan back on instead of a rubber gasket (like the one that came with my trans filter kit). UGH.
The trans housing is aluminum, yes? I was deathly afraid of gouging the surface by trying to pry the pan loose - I used a mini-prybar and was able to sorta apply some leverage against the lip of the pan by prying back against the trans itself with the prybar 'elbow', but again, It felt like I would tear up the lip of the pan before I'd successfully break the seal.
Long story short - are there any tips the DI.NET hive-mind can offer to get the transmission pan off without damaging it? Was I worrying too much when I shoulda been prying like a madman? Should I go practice on the 99 ES at the local Pick-n-Pull? :rollgrin:
I settled for draining and filling the trans with some fresh ATF+4 for now. Better than nothin'.
Thanks!
Thanks!
