Hi
Does anybody know what the following problem is. Recently I have had to go into work very early in the morning. It has been cold the last few days in AZ. My transmission acts weird when it’s cold (I hadn’t noticed this behavior since I work afternoon/evenings and rarely up in the mornings). Basically, it does what some people consider a bump shift but it’s more than that. It does not want to downshift in a normal way, it does AFTER a few seconds coming to a stop, with some RPM surge too. I have to keep my foot on the brake pedal firmly to make sure it remains at a stop and doesn’t lurch forward. If I let it warm up sufficiently, it does not do this. I’ve been trying to duplicate the issue in normal weather and I have made it do it a couple of times after aggressive driving/shifting when coming to a stop. It doesn’t do it if I drive in warm weather and in a normal driving way. The problem is at downshifting, when it needs to go from a higher gear to a stop in a hurry, it almost seems like something latches on, and it does not want to release in time. It upshifts perfectly. I had a drop service with genuine ATF+4 done like 6k miles ago and this is not the original tranny (replaced it like 3+ years ago and it has around 140k+ miles). No other symptoms, no codes. 02 2.7L Intrepid SE. Any ideas? Is my transmission showing signs that it’s in the way out?
Thanks!
Thanks!
