Hi, my 96 Intrepid Es has lost it's honk. some time ago it started acting up by loosing the dual sound. it used to sound stereo and now it's one single note sound. not long after that it started to sometimes work and sometimes not. it did that for a while and now it just doesn't work anymore. everytime i press the button to honk i hear a click noise coming from the fuse box on the side of the dash board and it's coming from the honk fuse relay.
what should i do to fix it to sound like the original?
and is that click sound normal when you press the honk button?
Hope someone can help me with this cause it's really annoying not having a honk.
Click sound= normal ops for the horn relay..Look under the front of your car and see if the horn wires fell off...if not find, out which relay clicks when you push the horn button, and swap it with another in that panel that looks just like it. If that doesn't work, you might need to replace the horns themselves.
DokuHitokiri said:
what does this have to do with your transmission?
unless you meaning the transmission of the signal to your horn?
I thought he just had the "honking transmission" option!:D
That's the 4.11 ratio, isn't it?
