I have an 98 intrpid and it wont go out of first gear and the engine light came on. Anybody out there have any idea what might be wrong? Would apprciate any advice. Thanks Rick
Have you checked for Codes Rick? Personally I dont think its Limp mode, thats usually second gear isnt it? When was the last time you changed the Tranny Fluid??? Have you been checking fluid level?
I had a tranny line break on me once and the thing just wouldn't even engauge into first. It sounds like you have a different issue. If I were you, I would take it to a dodge dealer(or trusted mechanic) immediately.
I would definately check your codes before you bring your car to the dealer. If your check engine light came on then logic says it would be a sensor of some sort. No?? Yes??
Rick, just for a long shot disconnect the battery and leave it disconnected for about 5 minutes.. This will reset the Tranny computer as well as your clock
