does anyone have a remedy for my problem..
the taillight bar that goes across the trunk rattles like a mother ****er i put peal and seal all on the inside of the trunk it stops almost all vibrations just the light is noisy
4 alpine type r 12"
kicker 600.1
well i know if you have the subs facing the trunk you will get more rattle then having the subs facing forward. i say get some dynamat and put it on the under side of the tail bar, should stop it all together and is much better then that sealer
o i forgot also you kknow the trunk light on the inside of the trunk? well i had to use syclecone on the plastic clip to prevent rattle and also i took off the plastic cover to the light.
so check that you will get some rattle there also
