1 - 16 of 16 Posts
I found this interesting. I thought I would share. :)
The last paragraph is of particular interest.
NOTE :THIS BULLETIN APPLIES TO ALL VEHICLES EQUIPPED WITH CHRYSLER AUTOMATIC TRANSMISSIONS EXCEPT 1999 AND EARLIER MINIVANS.
DISCUSSION:
A new transmission fluid (ATF+4(R) - Type 9602) has been developed and is being used as factory fill for all vehicles with Chrysler automatic transmissions. Until now, vehicles originally filled with ATF+2 or ATF+3 were to be serviced with ATF+3. Effective immediately, it is recommended that all vehicles with Chrysler automatic transmissions except for 1999 and earlier minivans be serviced with ATF+4(R). ATF+3 should continue to be used for 1999 and earlier minivans because of the potential for torque converter shudder during break in. For all other applications the ATF+4(R) fluid offers significant benefits as outlined below.
NOTE :ATF+4(R) MUST ALWAYS BE USED IN VEHICLES THAT WERE ORIGINALLY FILLED WITH ATF+4(R).
NOTE :SERVICE INTERVALS DO NOT CHANGE. THE SERVICE INTERVAL CURRENTLY IN EFFECT FOR A GIVEN VEHICLE SHOULD CONTINUE TO BE FOLLOWED.
NOTE :ATF+4(R) IS COMPATIBLE WITH ATF+3 AND CAN BE USED TO TOP OFF VEHICLES THAT CURRENTLY HAVE ATF+2 OR ATF+3. DO NOT USE ATF+2 OR ATF+3 TO TOP OFF VEHICLES THAT HAVE ATF+4(R) FLUID.
BENEFITS
^ Better anti-wear properties
^ Improved rust/corrosion prevention
^ Controls oxidation
^ Eliminates deposits
^ Controls friction
^ Retains anti-foaming properties
^ Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4°R is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change.
I WONDERED why my fluid was coming out so dark, after just doing a pan drop last year.
Definitly a good thing to know, very good find Warlord.
Wish there was a way to retrieve the ATF+3 I just put in my Durango without dropping the pan again!
There is. Use a syphon pump. Stick it down the dip stick tube. Mine was $12.
The job is alittle messy. I suggest you do it in the grass, with news paper layed out. Put on cloths your not afriad to toss.
So what's the verdict?
Use ATF+4 on 99s..... or follow the TSB?
I doubt that most people would have any problems with ATF+4 with a 99 or 98.. right?
I think you need to re-read that Mr. :)
All vehicles are to use the ATF +4 unless you have a '99 and earlier MINIVAN.
So to answer your question...both. :)
Man! My brother must be wearing off on me... with his dumb questions.
I tried this once with one of those little pumps that works with your cordless drill, sounded like a great simple idea but as Hypnos says prepare ot wear some fluid and make a big mess no matter how careful you are
Well of course it changes color.. :).. As does pretty much any fluid in a car (short of washer fluid, as it is not used by the car itself) Oil, coolant, and transmission fluid.
That is a cool find though.
Discussion Starter #13
The ATF +3 that came in the car when I bought it (three years ago) hasn't changed color. Well, maybe a tad, but barely noticeable.
I agree. My ATF+3 hasn't really changed.
Maybe the ATF+4 changes color more?
i will tell u as i just got it changed..the car shifts smoother..but now i have this damn odor in the oil..which was never there with orignal...and looks a little darker than orignal even after 68K miles lol...i personally made sure they filled in the right at+4 from mopar......huuuuuum!!!!!
1 - 16 of 16 Posts
