my left turn signal is not working it's just solid when I try to use it and it's makes this buzzing noise when I try to turn them on.
Bad relay? located under the dash up by the brake pedal IIRC.
Yep - flasher is mounted on a panel that contains several connectors, and hangs down to the left of the brake pedal. It's the black thing on the lowest left slot in that panel.
From an earlier post:
Below is a photo that I took of what RoR2 described. I've never had to remove mine, but people say that it is difficult to remove it, but there is a latch you can release with a screwdriver to get it out without much trouble [a slot that you stick the screwdriver blade into to press the release latch]. Before that became well known here, people would just abandon the old flasher in place, plug the connector into the new one, and zip tie it to a wire harness or air duct. Either way will work.
I believe that there are certain aftermarket brands and part numbers of supposedly the right type (5 pinners) that don't work correctly in our cars (they blow a fuse when the hazards are used) - perhaps someone who knows the details on that can post that info. Otherwise you can go with the OEM part.
The only black connector-looking thing in the photo is the flasher (for reference, the white thing to the right is the brake switch with it's plunger aimed at a little bracket on the brake pedal arm - pedal is below the bottom of the photo, and you can see the steering column shaft with u-joint further to the right, near top of photo is the air duct, and at very top of photo is the DLC connector):
