1 - 2 of 2 Posts
Hi ya all.
Been a while sence my other problem's with my Daughter's 2002 2.7L Intrepid but it's time to figure out a few small problem's.
At first the HVAC blower only worked on high speed setting and i replaced the blower reistor and it work's in all speed's now, But it appear's to have 2 high speed's. Another word's it has off, low, low-medium, Medium, high, high, No Medium-High. When running the ac Medium is to low and the next position that should be more air is in deed high and it will freeze u out of the car.
I tried another HVAC control assy. and it still had 2 high speed's.
Tks in advance for any help on this.
Tks Scott
Discussion Starter #2
I figured out the culprit.
When i installed the new blower resistor i alway's move the thermo fuse away from the red hot resistor coil's so it's not going to melt the new fuse and when i bent it out of the way i shorted it over from the 2nd to the highest circuit to the high circuit. Now it's working in all 4 speed's.
1 - 2 of 2 Posts
