Hi all,
I’m trying to replace the passenger side valve cover gasket on a 2000 Intrepid RT and it says to unbolt the AC compressor and swing/slide it out of the way. Is this as simple as it sounds? I can only see 3 mounting bolts (one is a dual bolt facing forward).
Happy New Year!
AJ
Yeah, it's easy. I believe there are 2 side bolts and the one bolt in the front. Took the front bolt and the side bolt closest to the front out and loosened the other one until I could swing it a bit. It doesn't take much swing to get the valve cover to come out.
Oh and make sure your a/c belt is off. :D
Should be 4 bolts on the side. Two at the side top and two side below to get the compressor off the bracket.
you have a 1st gen Intrepid Codyj all different up top on the 3.5L
CYLINDER HEAD COVER
REMOVAL
WARNING: DO NOT START OR RUN ENGINE WITH
CYLINDER HEAD COVER REMOVED FROM THE
ENGINE. DAMAGE OR PERSONAL INJURY MAY
OCCUR
(1) Remove air cleaner assembly and upper intake
manifold. Refer to Intake Manifold in this section for
procedure.
(2) Cover lower intake manifold with a suitable
cover during service.
(3) Disconnect electrical connectors and remove
ignition coils (Fig. 59).
(4) Remove nuts attaching wire harness to cylinder
head cover (Fig. 58). Move harness for cover
removal clearance.
(5) For right cylinder head cover removal perform
the following:
(a) Remove A/C compressor belt. Refer to COOLING
SYSTEM for procedure.
(b) Remove A/C compressor mounting bolts.
(c) Move compressor aside for cylinder head
cover clearance.
(6) Remove cylinder head cover bolts and remove
cover
