21 - 33 of 33 Posts
It is 95% done. All I lack is a another new tie-rod end to replace the one I stripped the threads on.
But, when I had them side-by-side I did not notice any differences in height or mounting hole locations. My best guess is the difference is in the spring compression rate. Although I would have thought the Special would have a stiffer spring, not a softer one.
It could be done by shortening the spring or a combination of that with a different spring rate. But it's only speculation to say how they did it. WIth the difference only being 1/2" or so, it's doubtful the difference would have jumped out at you just looking at them side by side without actually measuring.
Unity Manufacturing Info
From their web site
About Us
Unity Manufacturing Co.
1260 N. Clybourn Avenue
Chicago, IL 60610
unityusa
Phone: 312-943-5200
Fax: 312-943-5681
Hours of operation: 8:00 am - 4:00 pm CST; Mon - Fri.
Unity has been an innovative manufacturer of automotive, truck and emergency vehicle lighting products since 1918. The company was founded on the south side of Chicago and evolved into single, private ownership under Henry Rue Gross in 1923.
In the mid-1920’s, Unity started production of its line of post-mount spotlights. The company expanded into the manufacture of automotive and heavy-duty truck road lights in the 1930’s. Shortly after moving to its current 160,000 sq. ft. facility in 1960, Unity was able to expand into the manufacture of emergency lighting products for police, fire, and other emergency vehicles.
Throughout the history of motorized vehicles, Unity has adapted to customer needs and made products that improve the safety of motorists, truckers, off-roaders, police, fire, ambulance, utility, military, farmers, wreckers, snow plows and services vehicles of all kinds during nighttime activities and emergencies.
Today, Unity is the world’s largest manufacturer of post-mount spotlights. The company is also a major OE supplier of both auxiliary and emergency lighting products. Its product range includes post-mount spotlights, roof-mount spotlights, fog lights, driving lights, off-road lights, work lights, hand-held spotlights, deck lights, 360 degree warning lights and custom wire harnesses.
As an aftermarket supplier, Unity maintains a highly trained customer service department, responsive field representatives, and a wide assortment of popular products for on-time shipments.
As an O.E.M. supplier, Unity manufacturers its products in its own factories with in-house capabilities of chrome plating, buffing/polishing, machining, stamping, gear cutting, assembly, wire harness, CAD design, and prototyping. Its quality system has been certified as meeting the requirements of ISO/TS 16949:2009 and its environmental management system as meeting ISO 14001:2004. Unity is committed to not knowingly provide products containing minerals that contribute to conflict in the world as evidenced by its Conflict Minerals Policy.
Unity’s commitment is to produce products that exceed customer expectations, achieve the highest level of quality while offering our customers exceptional value.
Thanks for shopping with us!
Judging by that last post it looks like Unity manufacture automotive Lighting products only! When did they get in the suspension business?
El Crapo Struts!
The first major negative you visually see with Quick struts is that
the springs are only close / aproximate rating compared to oem.
Usually they go to the high side to be safe and then you have to
deal with a much higher ride height.
You get what you pay for. Yes , save the old stock struts as you'll
probably need em.
Generally speaking, most people have luck with KYB, but even then can be a crapshoot with the mounts. The best method (which has seen the most success) is reusing the mounts on OEM struts, repacking bearings with grease (or...buy them new, your choice), and putting them on your quickstrut of choice.
I've had KYBs on my 2000 since 2014 with reasonable success. They're getting a little noisy anymore but I think it may just be the fact that they've aged.
If the rubber in the OEM mount ever de-bonds (and that does happen) it makes an annoying sound at every up-down movement from imperfections in the road. If you get that sound and it's not sway bar bushings or end links (which is a more solid and louder "clunk" sound), and you can find OEM mount-bearings at a good price (ebay NOS), you'd need to replace the mount-bearing too.
Mine had 111k on it and my original struts were making noise from the mounts. After reading the many negative posts about Monroe on this forum (thanks guys) I decided to buy KYB complete smart strut assemblies. At first I was happy with them, the only difference I noticed is that they did make the car ride firmer. But they didn't last long. The passenger side started to go after 10k, leaking and making noise. Got a replacement from Rock Auto under warranty. Another 5k later and the drivers side started to creak so needless to say I had enough. Fortunately I never threw my original ones away and I bought new mounts from Rock Auto and installed them on the original struts. Since putting them back in, I have no complaints. My ride quality is better and no noises. If my originals go at some point, I'm not sure what I will replace them with.
My 02 had around 300K on the original suspension and steering components. For the front and rear struts I went with Detroit Axle, for other suspension components like lower control arms, sway bar links, etc, I went with DLZ. I bought all my bushings from MOOG, including the inner tie rod bushings. For my front and rear hubs, I also went with Detroit Axle. I still need to replace my lateral links and trailing arms in the rear, but will in all likely hood, go with DLZ parts with MOOG bushings. Now before you all get your collective panties in a twist, yes DLZ is a Chinese company, but I have been using their parts for going on 2 decades in multiple vehicles and have been very happy with their products. Yes, on occasion I get a bad part that fails early, but that has also happened when I buy genuine MOPAR parts as well. But overall, I am very happy with the performance of the parts I installed.
21 - 33 of 33 Posts
