My dashboard indicator lights on my 2002 Intrepid ES start to flicker about every 30 seconds to a minute. The gear indicator (P,D,N,1,2,3), trip odometer, and digital clock start flickering for a second then it goes back to normal.
Is this an indication of a low battery? If it is how much longer do you think I have left?
And once I start the car and if I'm driving a pretty short distance the car won't just go DEAD on me WHILE I'm driving, right?
Otherwise there would be no point in people getting a jump start if the car would just go dead once they started driving!
Thanks for all you input guys.
sounds like a shorted wire somewhere. If it was a bad battery your lights should all stay dim and the car not start or take a while to start. Best way to check take the car or battery to autozone and have them check.
The car did struggle a bit to start but that must be because I hadn't started it in about a week. But when I went out then started it again it started normally but the flickering began.
I'm concered that either something will happen on the way to AutoZone or once I get there I'll have trouble starting the car.
