What Peva said, and, If its a 2.7, a bad water pump can cause this;
If it is, stop driving it immediately, dont even start it until the water pump is checked out. Usually when they are to the point where oil/coolant is mixing, the bearing has failed in the water pump pulley, and it may or may not be running hot/overheating.
If the water pump is the issue, and oil/coolant is mixing (which is what you have) it is ready to fail catastrophically at any minute; it will either let the timing chain loose, or wash the bearings---in either case....engine will be done, and need to be rebuilt.
PCV system being plugged up can cause it in extreme cases.
Whatever the problem is, the cooling system will need to be completely flushed with an oil removing cleaner after the problem is fixed.
