98ES 85K miles
Steering wheel was crooked
Windshield was warped, finally started to split at least 15% of the way across. Dealer tried to tell me it was a rock yes the split started under the side plastic windshield cover. Must have been one bad ass rock.
Second windshield is slightly warped but hasn't split.
Rear door panel started to fall off, both panels were replaced.
The rear passenger overhead door handle was missing on of the bolt threads, rattles like hell.
Plastic piece missing on the seatbelt assembly on the passenger side.
Raidiator split. Oh that was a cheap fix, sheya right.
Brake light bulb on the trunk went out.
Dead cell in the battery caused the lights to dim when going uphills or when having a load on the engine.
Serpentine Belt replaced.
Dash rattles, getting worse
Tranny would drop into netural, sucked going up hills, PCM updates helped.
One of the struts is leaking, more or less their all asta.
Shall I keep typing, HEHEHE realize also this was probably one of the first Intrepids built as well since I got in in Dec of 97.
Still runs fast as hell, V8 Mustangs don't do so well over a 100. Ok that NSX spanked me fine I'll admit that.
