well i have the 3.2 so when i first start it up before it warms up i would shift into gear,well there would be a slight hesation and i would feal the car go into gear with a little budge to it... what could this be?
Been having the same problem, fluid is up and it only happens when the weather gets to 50 F or below. Have seen threads that have addressed thi problem and it seems there is an o-ring problem in the tranny. I've dealt with this for a few winters now. I just rev it up in park a couple of times after starting, then I'll hold my foot on brake and run shifter thru all gears up and down twice, not very fast, then back into park, and then into gear I wish to move into and it works out fine. Just my experience , maybe it will also help you!
sounds like it just needs to be warmed up to be able to shift... i notice this only durning fall - eairly spring.... thnkas for the help
