1 - 20 of 21 Posts
Ok I have a 97 3.5L
On the air intake coming from the air box and working your way toward the engine there is a hose (about 1.25 inch diameter) coming from the air intake, near the end of the accordian piece, that is about 4 or 5 inches long and runs to the back of the engine at one side. What is this hose for????
I noticed today that this hose has a nasty split in it and I'm wondering if it could be the culprit for my rough idle/misfire that is giving me a code 43. I had been assuming that it was gaskets again but it would be great if it were just this hose.
yea it prob could, its causing an air leak so it sposible it could cause your code. It's part of the crnk case ventilation system.
Turns out the the hose was the source of my first code 43 the other was as I thought the lower intake manifold gasket again.
Strang thing is with the bad hose and gasket I was getting 30mpg on the highway now after they have been fixed I'm only getting 26mpg. Is there anything I should check??? could something have been done or done wrong to reduce my mpg during the hose and gasket change???
i have the same problem. my hose is cracked and it leaks oil. i need to go to home hardware or home depot and cut a new piece.
Strongt said:
Is it #9 in the pic?
If it's split, it would cause a vacuum leak.
no it cant be #9, he said its a 1.25diameter hose. whats shown in the pic is way too small. its a hose that is right after the throttle body and it connects to the top left valve cover is what hes saying.
No offence DKILLA but wake up man, look at the last post before yours. It was #9 and it has been fixed.
I just revived this thread because of my decrease in MPG, I wanted to see if there was anything that could have been done inproperly or whatnot during the repairs that could account for the drop in MPG.
i dont need to wake up, the picture just looked kinda ****ed up to me. Could you take a pic if yours so i know what you're talking about. i honestly dont see this on my trep.
Discussion Starter #14
DodgeyAussie said:
This thread sux
Thanks for the ever so constructive input.
Now to get back on trac here is a reposting of where this thread was actually supposed to be going:
Strange thing is with the bad hose and gasket I was getting 30mpg on the highway now after they have been fixed I'm only getting 26mpg. Is there anything I should check??? could something have been done or done wrong to reduce my mpg during the hose and gasket change???
Change your air filter. When that pipe was broken, you were bypassing the air filter.
can anyone link me a pic for a 3.3l
i will circle the pipe which i am talking about and needs to be changed. let me try google.
brb ! :D
EDIT: this is the pipe of mine which is sweating oil, can i replace this with any garden hose?
Mopar or No Car
brb ! :D
I suggest you use automotive hose (rubber) and clamp the ends. Unless you find metric hose you'll never get the right size to make it fit snug ...
It's called a PCV hose. If you need to ask if a garden hose will work, you should probably just order a new stock hose from your local dealer. Just go up to the parts counter and ask for a new "Passenger's side PCV hose". They will probably have to order it, but it shouldn't take long.
Discussion Starter #20
Thanks for the input Hypnos but the air filter is fairly new and still clean so it should be flowing about as good as any standard paper filter flows. I really gotta get my CAI made soon though and put on a conical K&N
1 - 20 of 21 Posts
