can someone post up some pics of the wheel bearing..i want to know how easy it is to replace my self
I started to do mine but found it seized to the knuckle. All the pry bars PB blaster i tried could not get it off. Took it to a mechanic friend of mine and he use a torch to heat it over and over, finally came off. Besides that its as easy as brake pads replacement.
I usually remove the tie rod from the knuckle by hitting the side of the knuckle with a heavy hammer - works every time compared to beating the end of the tie rod and ruining the threads.
