Okay, I have a few questions about intrepid wheels. First of all, will 2nd gen wheels fit a 1st gen? What is the bolt pattern for an Intrepid? Is it the same on all LH cars? Will any other dodge vehicle wheels fit?
yes, 2nd gen will fit on 1st gen... the intrepid has a standard 5 lug pattern and most wheels with 5 lugs will fit. the stock wheels are between 15''-17'', so whichever you have it'd be good if you got the same size... if not you'd have to go to a dealer and recalibrate your speedometer
All LH vehicles share the same bolt pattern both first and second gen (5x114.3). You can always go bigger (to a point), but depending on your rotor size you can't always go smaller (not that you likely would). You won't have to recalibrate your speedo if you get the proper tires. By changing the sidewall ratio you can maintiain the same rollout, thus maintaining the speedo callibration... ;)
Wheels
5x4.5 lug pattern (or 5x114.3mm)
Anyone know the offset?
Wheel: 16"x7" (Stock)
Tire: 225/60-16 (Stock)
Wheel: 17"x7"
Tire:225/55-17
0.4% off - 60mph speedo - 60.3mph actual
Wheel: 18"x7.5" - 8.5"
Tire: 235/50-18
2.3% off - 60mph speedo, 61.4mph actual
Wheel: 19"x8"
Tire: 245/40-19
0.3% off - 60mph speedo, 60.2mph actual
http://www.miata.net/garage/tirecalc.html
I wonder if anyone makes a 245/45R18 to go with the 18" wheels I want.
Hardwarz
